Section Box 'BX' for Elevations
    Hi All
    I've just discovered this great shortcut 'BX' someone showed me a shortcut for elevations that performs the same action but I can't remember what it was. This is obviously without using the section box and manually moving it into place.
    Any Help?
    Thanks
    My favorite Keyboard Shortcut is KS.
    Yes, it's a Keyboard Shortcut for the Keyboard Shortcut tool!
    Once you're in there, you can pick the dropdown list at the top and filter by All Assigned.
    Then you can sort by either the command, the Ribbon Tab, or the shortcut itself.
    Dave Plumb
    BWBR Architects; St Paul, MN
      Thanks
      Regards
      Nathan Morgan
