I'm starting a project in R2017 and I notice that I can no longer select a text box, select anywhere on the border and drag/move the text leaving the leader shape intact. I have the move icon in one corner and the rotate icon in another corner and the only way to move the text box is to use the move icon, which leaves the leader behind or use the Move command which makes the text and text box invisible when moving it. Yikes, wtf is up with this?? Is there a setting somewhere that controls this situation?
R2017.2.1 Moving Text?
Originally posted by evan.dodds View PostHovering over the leader will let you pick the whole text object and move it. This works if you already have the text selected. If you don't have the text selected, then you can just click and hold and it will move the whole text object.I'm retired, if you don't like it, go around!
Dave,
you might find you have the 'drag elements on selection' button turned off, down bottom right of bottom bar.
when that's turned off, you have to click once to select an object, then click again to move it.
It's a safeguard, for example so you don't move something simply when you were trying to window something else.
when its turned on, I find i can with one click drag the text box, when it is there unselected. If it is selected, then yes, i use the move icon top left of text box.
hope all this makes sense.Motorbike riding is one long bezier curve
hope all this makes sense.I'm retired, if you don't like it, go around!
OTB text leaders default to the bottom. Does anyone know how to change the default to top?
Thanks
PatrickApril 25, 2011, 03:10 PM -
Or I'm crazy. I fear I'm missing something obvious and google isn't helping me either. I'm typing in some text notes on a few sections and details, but...March 25, 2017, 06:55 AM
I read a post at AUGI tonight that mentioned using the Modify button on the ribbon to finish typing or editing text. The intended technique to finish...
Channel: Blog Feeds
November 2, 2013, 05:15 AM -
I'm getting hammered by this box thing today - constantly having to re-do text because of the text entry behavior. Once the drop-down appears, keyboard...August 16, 2017, 01:23 AM
2017 added this menu after pressing esc from a text element. This drives me up a wall.
...February 9, 2017, 03:16 PM
