Windows cant be copied with copy and paste to current view option
    hi, i have a 6 storey building and hunderts of windows on the facade. I cant just use the copy to clipboard tool because the outer wall consists of 2 separate layers , so each time the windows land on either outer or inner walls. is there a way to keep the windows to exactly to be aligned?
    If you did one floor at a time and aligned each facade as as row, I believe if you copy/paste to selected levels it should copy in the same spot. You might try an offset in the family to force it to join to the outerwalls
