Is there possibility to set display setting in imported IFC model to particular floor plan like in Revit links (is there possibility to export IFC file with particular floor plans) ?
IFC floor plans
When you link revit file you can set it to display as in floor plans in the linked model (visibility/graphics overrides > Revit Links > Display Settings...). Then you have view range, plan regions, etc set as they are in the linked file.
Is there a way to do the same with IFC file? Or when you link IFC you link also DWG with floor plans for each level?
Morning all,
New here and new to Revit.
I have some newbie questions if possible:
Im creating an IFC from a Revit...July 8, 2020, 08:57 AM -
Hello all,
We are soon starting a relatively large (150,000 sf) highly detailed multistory housing project where the design architect is...-
Channel: Coordination Tools
October 1, 2020, 01:40 PM -
What is the best way to work between the Archicad platform and Revit? I am having trouble figuring out a seamless (or somewhat) way to work between these...October 11, 2017, 08:17 PM
*Revit 2016*
We have a project in which we are receiving AutoCAD Fabrication CADmep 2015 files from our mechanical HVAC and plumbing contractor....August 21, 2015, 07:45 PM -
Hi!
We just started to use the RevitMep2014 and our main problem is that the architect company gives us the plans in IFC format, and it works...March 31, 2014, 12:12 PM
