How to model cornered stairs with void
    How can I model these stairs?
    Also can I make a void in the model to allow for an underground entry?
    Cornered stairs is no problem, model the stairs by Sketch. A void in stairs might be a problem. Cant add a second boundary to make the void. So maybe this is better to model as a Generic Model.
      Or just use multiple stairs.
        I'm a bit confused. I don't know what you mean by "underground entry". But, if by "void" you mean you want the stair run to be a consistent thickness, then a combination of both approaches mentioned above would work: multiple abutting stair sketches. The stair tool is not adding a "fill" under the stairs, if that's what you're thinking.
