I've modelled up a monument sign. It's intended to have 5 different materials (most of them types of stone). I've made the model using an in-place-mass. I've found I can paint a surface of the mass with a material and schedule it, and I can click on the in-place-mass to get its volume. But I can't schedule the volume! Ideally I'd like to schedule all the volumes from the sign, but maybe I need to use a different tool? In-place-components seem less flexible than in-place-masses.
Calculate (and schedule) volumes from in-place-mass?
Is it possible to create a single schedule which would show two or more different area types. For example, could you create a single schedule which could...March 27, 2017, 05:09 PM
I have a finish that only occurs on a roof fascia. Is there a way I can get this to report to a schedule?
I have tried to create a parameter that...January 24, 2017, 03:49 PM -
We are looking at revamping our revit model for a major residential developer in our area. Currently a huge number of elements are drafted with lines...July 29, 2015, 02:14 PM
Is there a way to have spacing between groups of mark numbers in a multi-category schedule? I have a schedule that is sorted by the Mark number. But it...October 25, 2012, 04:24 PM
Lets say I have created wall schedule with type and volume. There are 3 types of walls, and I would like to see the total volume for each group.
...April 23, 2014, 06:58 AM
Monumetric Footer In-screen
