Hi There,
I'm fairly new to revit and can find most of what I need online however I can't find a solution to this challenge.
I have a small building with PC panel walls set down into a recess in the slab edge. I have used voids to cut the recess in the slab edge but i wonder if I can actually attach the void as a void extrusion to the base of the PC panel? This way when I insert the panel, it will cut the void in the slab edge for me.
See the attached image to see what my end result is that I need.
Thanks.
Thanks.
