Remove the "tail" of the spot elevation
    As captioned, how can I delete the "tail"?
    Thank you
    Click the tag and uncheck "Leader Shoulder"
    Before starting to tag an elevation, uncheck "Leader" and you won't have to worry about it at all.
      Hi billytsoi
      You need to click on the spot elevation, then in the properties palette there is a box called "Leader" which If selected make that the spot elevation includes a leader line. When not selected, no leader line displays and there is other one box called "Leader Shoulder" which adds a shoulder to the leader line, that normally should hide the Leader line, HTH
      E.A Poe
        You Write more quickly than me, LOL :laugh:
        E.A Poe
          Thanks all of you
          but the shoulder is still here
