After linking in a dwg file, should I move the file to the survey point origin or move the survey point to the file? I seems that moving the survey point causes problems when rotating to project north because it rotates around the original origin regardless of where the survey point is moved? Is it possible to rotate around the new survey point position when using project north and true north rotation?
Linked dwg File Positioning
Link in CAD file, move the CAD file to where your building model will be (ideally near the Project Base Point i.e. Revit Origin, between the 4 default elevation markers). Rotate the CAD file as needed to allow your building model to be orthogonal or mostly orthogonal to the sheet.
After doing these, run Acquire Coordinates and choose the CAD file. Change the view to True North and you will see the view change back to the CAD file's original orientation. Change back to Project North to make the building model orthogonal again.
That's the method I've been using for years. Using Acquire Coordinates after you have the CAD file placed and rotated the way you need it, will cause Revit to automatically put the Survey Point at the CAD file's origin point.
Hi Guys
As an AUGI refugee, I'm looking forward to the new beginning on offer here.
My issue is with a linked DWG in a project...December 17, 2010, 09:35 AM -
i'm trying to sort through this shared coordinate stuff for a project and am a bit lost and confused.
Our model (arch) is 60% or more...February 12, 2013, 02:43 PM -
Hey all,
Having some fun with setting up a survey in revit from a supplied survey dwg. This has coordinates which reference the Perth coastal...February 11, 2014, 04:30 AM -
My land surveyor has given me a survey of a building and large garden as a DWG with 2D and 3D data in it.
We have done this dozens of times...November 9, 2021, 01:55 PM -
I have imported a CAD file into a new project. It is by default at true north. When rotating to project north, the center of rotation is at the Revit...August 1, 2017, 03:40 PM
