Hello,
We have a problem with a filled region. simple you might say!
Basically there is a filled region in a plan view, overridden with 50% transparency. The region shows perfectly fine in the plan, but when we put the plan on sheets, this region becomes sort of Opaque. It is the same situation on different levels.
If I try to recreate the problem in a new project, everything is perfect, no problem. we do this all the time.
It also prints corrupted like that.
What we already tried:
-Changing the type of region to transparent makes it completely transparent, leaving only walls colored... really strange.
-View is in hidden line mode,
-No hidden elements underneath that could disrupt this
-No filters
-No images underneath the region
Please view attached snip,
Any help is greatly appreciated.
-No filters
