Schedule/Quantities - Material
    Hello all,
    Could you tell me, if I can put the Material Name, material description or something that will be indicate the material, in a regular Schedule/Quantities?I cannot find this field available.
    Thank you in advance!
    Regards,
    Maria
    In a Material Takeoff schedule, you can put any material properties (Look for parameters called Materialescription, Material: Area, etc.) In an element schedule you can schedule the material name only, as long as the parameters meets the rules for getting it on the schedule (shared or project parameter)
    Julie Kidder
    Architect + BIM Director
      In an element Schedule (Schedule/Quantities) I can't find the field material name..do you know why?
      Thank you!
        You have to schedule the parameter the material is applied to.
        For example, if you have a furniture family that you want to schedule the seat material, you would schedule a parameter that you might have called "Seat Materaial". That parameter would need to be default in the family (I'm not sure any material parameters are), a shared parameter, or a project parameter. If it's affecting an elements graphics it would need to be used in the family, and would need to be shared.
        Julie Kidder
