I'm trying to join beams with slabs. However, when I press Join, Revit is not allowing me to even select a beam. It does allow me to select any other element though, including other structural elements such as columns. Does anyone know what the reason might be?
Joining beams to slabs
Am I doing something inherently wrong? I made a test on another machine on an older version of Revit. I'm modelling a simple structural slab and a beam. Both of them have concrete material applied. When I'm trying to join them I run into the same issue. I can select the slab but not a beam. Unjoin command is not doing anything either.
I think we may need more info, or a chance to investigate your model.
Very quickly, I opened v2018, began a new project using an OOTB Structural Template, drew in a floor and added some concrete beams. In previous releases, the material had to be THE EXACT SAME material in order to join. However, after investigating my test project, my floor is lightweight concrete and my beams are Cast-in-Place Gray. I was not expecting them to join, but they did.
So, I'm not sure what is going on with your project.Leanne Zaras, CDT, LEED AP
Thank you both for your replies.
The beam is not pinned and I can select it outside of the join command. Maybe I'm doing something wrong while creating the beam family? I'm attaching the link to the test file: https://drive.google.com/open?id=0B9...EN1aDQ2YzNGV0E
Originally posted by panbystry View PostThank you both for your replies.
The beam is not pinned and I can select it outside of the join command. Maybe I'm doing something wrong while creating the beam family? I'm attaching the link to the test file: https://drive.google.com/open?id=0B9...EN1aDQ2YzNGV0EMichael "MP" Patrick (Deceased - R.I.P)
Originally posted by MPwuzhere View PostI suggest using the concrete beam that is in the library, which uses a profile sweep instead of a sketch extrusion like yours. When I changed yours to a profile sweep it worked as intended.
This solved it. Many thanks! I reckon it must be a bug though, I imagine both beams should behave in the same way.
Originally posted by panbystry View PostI'm trying to join beams with slabs. However, when I press Join, Revit is not allowing me to even select a beam. It does allow me to select any other element though, including other structural elements such as columns. Does anyone know what the reason might be?
The reason is with the family. If we put the material behaviour of the beam as concrete and put the visibility of the 3d geometry(sweep) to be visible in coarse, medium and fine then this family will auto join with slab or other concrete beams in project.
Next, if we put the material behaviour other than concrete(steel), and put the visibility of the 3d geometry(sweep) to be visible in coarse, medium and fine then this family can be used with join tool in project. We can select the beam using join tool.
In most of the structural framing family, the solid geometry will be set as invisible in coarse mode.
I have two horizontal steel beams which approach each other with an angle of ~150 degrees between them. I cannot get them to join. When I try "Beam/Column...
August 16, 2012, 09:39 AM -
I have a problem creating some pre-cast concrete beams. Revit won't snap at any point of existing geometry and and the beams do not join between them....October 28, 2015, 12:57 AM
Hi Reviters,
I've tried the search function on le Google and on the forum to no avail, so thought I'd ask you all.
I have a...-
June 29, 2017, 07:27 PM -
Hi all,
I've got a simple masonry building with precast concrete floor planks supported by steel beams at the same level (via shelf angles...-
February 4, 2014, 10:26 AM -
Hell everyone! I'm a long time lurker here, and I finally decided to jump i feet first. I'm having a problem with the beam join/miter tool. It seems...
August 4, 2011, 04:07 PM -
