Drop Down List Parameter
    Hi everyone
    Is it possible to create a drop down list as a family parameter? In my example, I have a grabrail which is available in three different diameters, 32, 38 and 50mm. How can I have this parameter available in these three sizes only?
    Why not just make 3 types in that family, no need for people to set the parameter, just to choose the type.
    But as far as I know if you make multiple types you will get a drop-down with the values you used in the multiple types.
      If its a nested family you can use a <family type> parameter, but unfortunately when setting this in the project your drop down list will be populated with every family type of that category that is available in your project.
      Would be nice to have it limited only to types available in the family. Wish list item...
        But as far as I know, if you make multiple types you will get a drop-down with the values you used in the multiple types.
        Hi Robin
        The reason why I'm trying to avoid this is that each size of grab rail has three different configurations so I will end up with dozens of types.
          Just did a test and it seems my idea does not work with dimensions, just with text, so you will not get a drop down list from dimensions even if you have multiple types in your family, works with text only
          You can use a set of 3 Yes/No parameters that say 32, 38 and 50 and an IF formula in the actual parameter that sets the size. This way people just have to select one of the 3 sizes and the parameter is filled in according to that selection.
            something like this:
            if nothing is selected it still uses the 32mm, so it will not break anything and if multiple sizes are selected it always uses the largest of the sizes selected. As far as I know it is not yet possible to always have just 1 out of 3 options selected.
            Code:
            if([50], 50 mm, (if([38], 38 mm, (if([32], 32 mm, 32 mm)))))
              This might be what you're after although ive never needed to do it this way
              Revit OpEd: Controlling User Choices in Families
              Edit - so ive been building some new casework families and this method works great. Makes the file slightly heavier but simpler for the user and the upside (hopefully) is less families in the project.
                Oh Elton, I hijacked your idea and posted it on the idea section of the Autodesk forum
                https://forums.autodesk.com/t5/revit.../7281395#M9924
                  It is a good work-around. There are multiple suggestions for this on the Ideas forum, including my own. If only we found searching that site easier we could put all our votes into one suggestion rather than diluting them across a bunch.
