I created an in-place mass where I joined 3 masses. I want to create walls-by-face in order to schedule this object, but when I attempt it, revit creates walls based on the masses BEFORE they were joined. Is this by design? I think it's obvious what I'm trying to do - can anyone recommend a different strategy?
Creating wall-from-face, wall appears as if masses weren't joined
So my intent is to use in place mass for representing existing walls with varying sizes from the site survey for a project that will be demo'd later....May 24, 2017, 08:46 PM
Hello again ...
I had to post it again!!! NOBODY KNOWS THE ANSWEAR GUYS???????????????????????????????????
I want to join a...April 19, 2012, 07:04 PM -
Is it possible for the ends of walls to flex with a mass, rather than their face? Eg. attached, where the wall is perpendicular to the mass surface which...March 3, 2012, 06:26 PM
I have and inplace mass created from 2 lines. The resulting planar mass is not perpendicular to any of the main axis and is trapezoidal in shape.
...July 18, 2014, 10:55 AM -
I did my concept design by creating a new mass, after i putted the mass inside the model and then i chose which surfaces had to be floor and...November 21, 2012, 07:04 AM
