Earth Hatch Pattern: Scale and Rotate
    I cut a section through a building and the earth hatch pattern always comes out too large and orthogonal.
    Is there a way to change the hatch pattern so that it's @ 45° and smaller scale?
    Thanks in advance
    Juan Carlos Moreno
    Sisley Cosmetics
    For rescaling, it would be fairly simple to edit the .pat file... but the rotation would be a nightmare to figure out (at least to me)
    I´d suggest that you make a new pattern from scatch, using Hatch22 :beer:
      i have a 45° earth pattern for revit which maybe what you need, but i cannot post .pat files here
      the attached earth45.txt file should have it's file extension changed back to .pat format, then import into revit at whatever scale you like. open .pat with notepad to edit pattern.
      the new pattern dialogue .jpg shows where to input scale
        Originally posted by elton williams View Post
        ....but i cannot post .pat files here...
        Now you can
          make your own patterns:
          http://docs.autodesk.com/REVIT/2010/...49ed4-7fd9.htm
            Thanks so much for this!
