Is their anyway to change the calculation method that revit uses to calculate Cold water flow rates? All the "architecture" already exists for the current "Fixture Units" method, I would just need to change the actual calculation used to suit the British Standard.
Flow Rate Calculation
Yes its possible.. but you will need to do a bit of C# programming and make an add in.
There is the possibility to replace the pipe/duct calculation servers with your own. Theres some info on this here;
I managed to get this working for tapwater using dutch 'Tapeenheiden' instead of Fixture Units.
It works, but the only examples I could find where from 2013 and I had to strip it right down to the minimum because so many things where old and no longer worked with the API. I dont have a lot of programming experience so its amateur stuff... so feel free to have a look and copy it if you like.
Its a Visual Studio 2015 project. I suggest you download the full example too and start with that for your own calcs.
(BTW the actual WFU calculation is ridiculously simple, it just looks up a table. If you can get the rest of the add in working, just replace that bit with your own formulas.)
I gather from the lack of available examples that almost no one has tried this...
EDIT: Als je wil toch de berekeningen gebruiken volgens NTR3215, je zal een geschikte family moeten maken. TE SE en constant debiet zijn door hetzelfde WFU parameter gestuurd als volgt;
Last edited by josephpeel; August 10, 2017, 12:52 PM."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Put the compiled .addin and .dll files in the folder C:\ProgramData\Autodesk\Revit\Addins\2016 (Or other version.)
Then when you open revit it will run as a service (There is no AddIn button) and you can select it in Mechanical Settings
Note that if you make changes (In Visual Studio), build and overwrite the files, you still need to close revit and open it again for it to update. Which makes debugging a bit more tedious than a normal addinLast edited by josephpeel; August 10, 2017, 01:35 PM."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Hi guys,
I would like to use Dynamo to size pipes and pipe fittings Pipe size=(Flow rate) or Pipe size=(Fixture Units) with excel or not , within...-
Channel: Dynamo BIM
March 14, 2018, 10:27 AM -
Hi guys
I have a question regarding Fixture Units (FU) of Plumbing fixtures in Revit.
In my country DIN norms are accepted,...-
Channel: MEP - General
February 14, 2014, 01:34 PM -
Hello everyone,
When I access the family editor from Revit 2017 and check the configurations of an original MEP Toilet, the "flow configuration"...-
November 7, 2016, 06:15 PM -
I have the attached file which is an add in for custom pipe flow rate calculation. However the formula used is wrong, I have tried changing it myself,...
Channel: Commercial & Free Add-Ins/Extensions
November 6, 2018, 02:42 PM -
Has anyone (in the UK) found a way of using revit to do pressure drop calculations/pipe sizing tool.
Obviously it appears Revit leans more...-
March 8, 2016, 03:11 PM -
