I have a precast concrete wall with timber framing on the inside and plasterboard lining.
If I make this as one wall (instead of having a precast concrete wall then a separate timber framing and plasterboard wall) I have issues at columns where I want the timber framing to stop but the precast concrete to continue through.
I have attached two images - one with the timber framing stopping at the column (how I want it to look) and the other with the timber framing continuing through (I cant figure out how to avoid this when the precast concrete wall, timber framing, and plasterboard lining is one wall).
Is there a way I can make this work with it as one wall?
If I have it as two separate walls I get into problems with inserting windows and the windows not trimming out the timber framing / plasterboard lining wall.
