I have detail views that are located in a template file that our office made. I want to insert some of them into my current project, so I go to the ribbon, and choose Insert tab, from there I go to "insert from file" --> "insert views from file" and when I go to select the template file, it is not listed, so from there I go to the drop down to "show all files regardless of extension, which allows me to choose it, but when I do, nothing happens. I swear I have done this in the past with no problems. Any ides?
Inserting 2D views from Revit template file to Revit project file
And why not?
I don't understand why .rte files can't be used with "Insert from file". Other than Worksets. AFAIK, they are the same as .rvts
I could swear I posted a "Revit Idea" about that long ago, but I can't find it.Dave Plumb
BWBR Architects; St Paul, MN
I'm just wondering ... Are they same things?
Customized set up project with empty geometry (.rvt)
Customized set up template with empty...October 9, 2012, 11:43 PM -
I am not able to use this feature anymore. Whenever I try to insert views, i will pick the project file, and nothing will happen. I have tried restarting...March 2, 2021, 01:39 PM
I bumped into a subtle conflict this evening. I created a new file from a stock template. I then used Insert from File > Insert Views from File to...
Channel: Blog Feeds
May 16, 2017, 02:15 AM -
We use the 'insert views from file' command to bring our standard details into a project. However, the inserted views don't seem to bring the applied...May 15, 2017, 11:04 PM
Insert from File allows us to import views from another project, views like schedules, drafting views or even sheets that contain either. It is biased...
Channel: Blog Feeds
March 29, 2015, 03:15 PM -
