Hi there,
I am working on a Revit library and therefore am looking for a way to prepare the families that can be used right away, with the least adjustments needed.
Here is a railing family that uses 2 handrails at heights 700mm and 1000mm. All goes well until I check the upper extension - the resulted height is totally random. Is there an elegant solution to set this from inside the family or is it going to be sweat and tears each time?
