How has the identity data for this family been created?
    Hi there,
    When the attached family is loaded into the project environment, if one clicks on Edit Type and scrolls down to the Description parameter found under Identity Data, it is possible to select the description from a drop-down list. If i clock on the family and Edit Family I don't see anything which references a drop-down list.
    How is this possible?
    There are 3 types in that family with 2 different values for description. The pull-down menu just shows you those 2 values, already in the family. Make a third type and enter a different value for description and that will be added to the pulldown as well.
