So, all you assembly gurus out there...the place that I work uses curtain walls as assemblies and then uses the views of those assemblies on a sheet of window "types" which show front elevation views of the window (curtain wall assemblies) with dimensions, detail call-outs to drafted window details, etc.
Here is the issue I am coming up against:
I have a curtain wall assembly that is in a wall that is not orthogonal to the rest of the walls in the project (lobby of a school). When I try to generate a front elevation "view" of that assembly, it is skewed by the same angle that the wall is skewed from the rest in the project.
Is there anyway to generate the correct front elevation view (without putting a "copy" of that assembly on one of the orthogonal views or trying to use the interior elevation tool to generate a "view". OK assembly gurus...rise to the challange!
Thanks,
Thanks,
