i am using "user keynotes". on only one sheet there is a keynote that shows up in the keynote list on the sheet. it is not at all a keynote, it is just text. i checked the txt file where the keynotes are coming from and I cannot find that particular sting on text anywhere in the txt file. I am attaching screen shots of the keynote list that is on the sheet, the path that is directed to the txt file and the actual txt file.
mysterious keynote showing up 2017
I wonder if an element got tagged using a different keynote file and it's just legacy because it's tagged in a view somewhere.
*** Well scratch that, changing the keynote file returns the keynote as a ?, which makes sense. It can't find what it's looking for ***Chris Heinaranta | Architectural Technologist
If we are talking about the "---Accessibility", then the property in question is the "Key value", not the keynote text. The Key value can actually be edited in Revit to be independent of the text, and therefore would not be in the keynote txt file. If this is the case you could use the "Highlight in Model" function to find the element. If that does not work, then you can use Ideate Explorer.Glynnis Patterson, Architect
www.ideatesoftware.com
Originally posted by GlynnisPatterson View PostIf we are talking about the "---Accessibility", ...
So did I...
Select the keynote tag, change the value in the properties palette and it schedules with nothing to be shown in the keynote file. Pretty much defeats the purpose of a keynote file. My gut feeling is you shouldn't be able to do that. Now, on the other hand... is there a situation where this would be a benefit?Chris Heinaranta | Architectural Technologist
I'm working on a project where we were handed over a Revit file that has element keynotes...but the keynote text file is missing (it was not provided...May 24, 2017, 06:50 PM
Can someone tell me if we can have 3 columns keynote? Currently, on keynote schedule its shown only keynote value and text. I want to add another column...January 3, 2021, 04:34 PM
Hi allI have a project that has been going on for a while and everything had keynotes (user and element) but when I had to transfer all the projects onto...February 6, 2014, 02:04 PM
When you use keynotes and realize you need to revise existing keynote information it easy to change what the keynote text value is. We just need to edit...
Channel: Blog Feeds
February 13, 2015, 04:15 PM -
I am trying to understand the use of keynotes, and this is what I have noticed so far:
I have two different basic walls
Both have...March 30, 2012, 11:58 PM
