Batch deleting worksets
    Hello,
    I am merely a beginner with Dynamo, and we are trying to automate everything related to workset creation/editing/deleting/managing them.
    So far we have scripts to create worksets from excel files, assign elements to worksets, and now what we need is a script to delete all unused worksets.
    I could not find anything online about it, and I don't really know where to start with it.
    Does anybody have a script or some idea on what would be the best way to do this?
    If you install the "ArchiLab" package, it contains Get all Worksets and Delete Element nodes.
    Edit: (Ah, I see. Just reading on the DynamoBIM forum and deleting worksets is not possible via API.... They do not behave like other elements. You can probably find a way to check which worksets are empty and rename them though, so its obvious what you need to manually delete)
      additional references / workarounds:
      https://forums.autodesk.com/t5/revit...t/td-p/6610832
      https://forum.dynamobim.com/t/delete-a-workset/13420/5
      www.polyninestudio.com | @Twitter |[email protected]
      FIND AND REPLACE MATERIALS FOR REVIT PLUGIN: www.polyninestudio.com/findreplacematerialsrevit.html
