assembly sheet reference
    Just wondering on how others have reference assemblies between documents? We are using assemblies to create our precast schedule, however we can't reference each assemble to their sheet. We have tags that can reference the PC panel and the material but not back to sheet. The only way I think can around this it to create and manual parameter matching the sheet number and having corresponding parameter in our tag.
    thanks
    maybe, instead of creating assembly schedule, you should create Sheet List and you are able to add Assembly Name to this schedule, so you would get information you need?
    "If I have been able to see a little farther than other men, it is because I have stood on the shoulders of giants."
    www.konstruktoriu-klubas.lt
