Hi All,
I've modeled the topography and placed a building pad. Now I'm trying to do a plan of the basement, which partially cuts through the topography and a section. In visibility I changed the section fill to solid gray. In the section view the fill appears only under the building pad and in the plan view it does not appear at all. I'm using Revit 2017.
