My material wont wrap around the ends of my walls
    i need the red panels to wrap around the corner
    also if anyone can help me with my hot mess awnings that would be great
    Try to change the wall join. Use miter type of join instead of square off.
      A miter join as kovacheva mentioned will work but it can affect things in plan. Depending on how your walls are built a better option may be to pull one of the walls back and trim them together. It could also have something to do with having walls underneath your red walls but it is hard to tell from your image.
      chad
