I created 3 applications that performs the same processing: "Load a family in revit"
#1 FormElementHost (windows form + usercontrol wpf elementhost) : (lose focus)
#2 FormNoElementHost (windows form) : (not lose focus)
#3 WindowWPF (Window) : (lose focus)
Even if I use an ElementHost to host a usercontrol wpf in which there is a wpf button, the focus does not work in the windows form (case #1)
Link of video with the 3 examples
Link project visual studio (addin revit + family 2015/2016/2017)
Link forum revit api
1)FormElementHost (windows form + usercontrol wpf elementhost) : (lose focus)
-Command:
-Form (System.Windows.Forms.Form) :
-UserControl WPF (System.Windows.Controls.UserControl) :
2)FormNoElementHost (windows form) : (not lose focus)
-Command:
3)WindowWPF (Window) : (lose focus)
-Command :
-Window (System.Windows.Window) :
UtilsFamily :
-Command:
Code:
[Transaction(TransactionMode.Manual)] public class FormElementHostCommand : IExternalCommand { public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements) { FormElementHost form = new FormElementHost(commandData); form.ShowDialog(); return Result.Succeeded; } }
Code:
public partial class FormElementHost : Forms.Form { ExternalCommandData _commandData; public FormElementHost(ExternalCommandData commandData) : this() { _commandData = commandData; } public FormElementHost() { InitializeComponent(); this.userControl11.ClickEvent += UserControl11_ClickEvent; } private void UserControl11_ClickEvent(object sender, EventArgs e) { Family family; string message; UtilsFamily.LoadFamily(_commandData.Application.ActiveUIDocument.Document, out family, out message); } }
Code:
public partial class UserControl1 : UserControl { public event EventHandler ClickEvent; private void RaisesEventClick() { if (this.ClickEvent != null) this.ClickEvent(this, new EventArgs()); } public UserControl1() { InitializeComponent(); } private void Button_Click(object sender, RoutedEventArgs e) { RaisesEventClick(); } }
-Command:
Code:
[Transaction(TransactionMode.Manual)] public class FormNoElementHostCommand : IExternalCommand { public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements) { FormNoElementHost form = new FormNoElementHost(commandData); form.ShowDialog(); return Result.Succeeded; } }
Code:
public partial class FormNoElementHost : Forms.Form { ExternalCommandData _commandData; public FormNoElementHost(ExternalCommandData commandData) : this() { _commandData = commandData; } public FormNoElementHost() { InitializeComponent(); } private void button1_Click(object sender, EventArgs e) { Family family; string message; UtilsFamily.LoadFamily(_commandData.Application.ActiveUIDocument.Document, out family, out message); } }
-Command :
Code:
[Transaction(TransactionMode.Manual)] public class WindowWPFCommand : IExternalCommand { public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements) { WindowWPF window = new WindowWPF(commandData); window.ShowDialog(); return Result.Succeeded; } }
Code:
public partial class WindowWPF : Window { ExternalCommandData _commandData; public WindowWPF(ExternalCommandData commandData) : this() { _commandData = commandData; } public WindowWPF() { InitializeComponent(); } private void Button_Click(object sender, RoutedEventArgs e) { Family family; string message; UtilsFamily.LoadFamily(_commandData.Application.ActiveUIDocument.Document, out family, out message); } }
UtilsFamily :
Code:
public class UtilsFamily { public static bool LoadFamily(Document doc, out Family family, out string message) { family = null; message = null; // ask user to select a family file System.Windows.Forms.OpenFileDialog fileDlg = new System.Windows.Forms.OpenFileDialog(); fileDlg.Filter = "Revit family (*.rfa)|*.rfa"; fileDlg.Multiselect = false; if (fileDlg.ShowDialog() == System.Windows.Forms.DialogResult.Cancel) return false; using (Transaction tr = new Transaction(doc)) { tr.Start("Load family"); if (!doc.LoadFamily(fileDlg.FileName, new FamilyOption(), out family)) { message = "Could not load family !"; tr.RollBack(); return false; } tr.Commit(); } return true; } }
