Most of my internet searches on this old topic seem to suggest that there still isn't a good solution for this but I'll ask again anyways. I'd like for my Windows to maintain their head height location when adjusting type sizes rather than traveling upwards if the size gets taller. I realize that Revit was hard coded to manage this through sill height for commercial preferences. I've played around with just about every possible combination of reference plane "Is Reference" property, "Defines Origin" property and even "Pinning" the head height plane with no success. Oddly enough, I have found some older manufacturer window libraries that actually function how I'd like (2014 ver. A&L Windows for example) but when I recreate their setup to the "tee", I still can't get my windows to mimic their behavior. Does anyone have the magic formula for the window setup or should I just continue to deal with it as is? Thanks in advance! -Dave
Window Head Height Constraint
Thanks for the reply ScubaMan,
So I gave your trick a shot, but it did not work as expected. The top of the window is still moving up/down after changing window sizes which is what I was trying to avoid in the first place. Looking at your images above, what are the reference plane properties of each of your horizontal planes, in other words where is your "Defines Origin" located and what is the "Is Reference" value for each of them?
Thanks! DaveLast edited by SuperDave; July 21, 2017, 12:42 PM.
Originally posted by ScubaMan View PostSorry for the three images don't know what happened
Thanks Cellophane
Super Dave,
Yep you are right. It works in the family but not in a project. Idea two. You can draw a reference plan in your project and align lock all the windows to it. If you want control you can also dimension it to a level and add a global parameter to it allowing you to change all windows head height at the same time.
I'm experiencing some difficulties trying to create a simple window with two sliding panels. I need to create one parameter to set the window height from...
January 16, 2013, 01:53 PM -
I'm trying to create some new windows and seem to have completely broken something. When I input the sill height in a project the window is offset by...
February 3, 2013, 04:47 PM -
Hi, i have two types of window as you can see int the image te rectangular work perfect with me bu curve not working perfect especially in height....
April 15, 2012, 03:29 PM -
Hi.
I created a window family with Rough Width and Rough Height as instance parameters and Height = Rough Height (*)
and tag that shows RW,...-
June 29, 2017, 08:45 AM -
Does the 'Sill Height' value only report from the bottom of the opening cut, even if there is a 'Default Sill Height' dimension established elsewhere?...
February 24, 2017, 03:27 PM -
