I am having some visibility issues with views and said views on sheets. an example is I have a view with a fill region that has transparency to it. it looks transparent in the view. once I place the view on the sheet it loses its transparency. anyone have this happen and if so what was the fix?
visibility issue with view and view on sheet 2017
What is the current best practice on back-referencing (sometimes known as callbacks) please?
Technically it works in that my viewport...April 3, 2020, 07:52 AM -
just wonder if there's easy way to find on which sheet the view sit, we didn't use not on sheet PB method due to many dependant views, and just too many...August 24, 2012, 12:14 AM
Hi there. I have a problem with the resolution quality of 1 view on a sheet that has 4 views in total on it. 3 of the views are floor plans. 1 of the...
Channel: Out There
April 1, 2018, 02:50 PM -
Might seem a little picky but you can't put an empty drafting view on a sheet. You get this complaint/warning if you try.
If...-
Channel: Blog Feeds
August 12, 2011, 04:10 PM -
Hi guys, me again.
How can I make it so my graphics/shading in a sheet view are not copied into my , say site plan. I copied the site plan...September 15, 2013, 12:42 PM
