Simply Complex: Ever wanted to change the floor thickness type property of your structural floor slab using Dynamo? If so why not also make it so it uses logic or an engineering rule of thumb? See the image below to get started.
Note: Feel free to use your own rules of thumb for min slab thickness. If you are not sure what rule of thumb to use ask your fellow structural engineer!
