LineWeights from .dwg files transferring
    I have noticed that with Revit 2017.2, whenever I link a .dwg detail to a project, the lineweights do not automatically change to reflect the same representation that they have in the .dwg itself. I have to go into the Object Styles and manually change it for every detail that I import. Anyone else have the same problem? Am I over looking something? This has never been a problem in the past.
    I believe the dwg line weights need to be set by layer. If they are set correctly then I'm not entirely certain
    chad
      Have you lost your Import Lineweights file?
      There's a little-known and well-hidden option that sets your DWG Colors-Revit Lineweights mapping.
      It's on that little tiny arrow at the bottom right of the Insert tab's Import panel:
      I think by default, it's somewhere under C:\Program Files, but the dialog box will show you the path.
      This is a simple text file that has a row for each Color specifying the Revit Lineweight.
      First row is what lineweight is assigned to Color 1, second row is Color 2; etc, etc up to 256.
      Dave Plumb
      BWBR Architects; St Paul, MN
        That was it, thanks. I guess I forgot to load it into our template.
