as a proposed solution to an ongoing issue with R2016 C4R I am preparing to uninstall and reinstall R2016 and C4Rv9. There are some very exacting instructions on the Autodesk support site regarding how to uninstall Revit completely, except they say "be sure to backup any custom family or template files prior to following this procedure". All of my family and template files are not in the Revit folder locations. I have backed up my Win10 registry, my revit.ini file, my keyboard shortcuts. Is there anything else that needs to be backed up to allow me to relatively easily get up and going again? My plan is to reinstall all of my 3rd party apps so no need to back those up. Anything else?
What files/folders to backup with removing/reinstalling Revit?
Revit add-ins: Purger (delete UNUSED and selected line patterns & line styles, find & delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager (with bunch of other features) at Autodesk App Store, View Filter Manager ML, SolarDaylight
Originally posted by Artejon View PostI'm retired, if you don't like it, go around!
Originally posted by Markus View PostFor versions newer than 2014, user preferences are no longer stored in the UIState.dat.
They got moved to the Windows Registry: HKEY_CURRENT_USER\SOFTWARE\Autodesk\Revit\%RevitVe rsion%\WorkspaceI'm retired, if you don't like it, go around!
I need help with my revit deployments. I set my user files to be stored in a temp drive on our server, how do I tell Revit where to store all the temp...August 5, 2016, 05:32 PM
I don't think there is currently a way around this problem, but would love autodesk to do something.
I run into an issue...April 21, 2020, 02:58 PM -
Revitform.org member "Cellophane" dropped this reminder/tip recently....
When you save project files that DO NOT use worksets and-
Channel: Blog Feeds
June 4, 2013, 03:15 PM -
I've got a recurring issue, since about December that is. I did some extended work for a client and we set things up so I could have access to resources...
Channel: Blog Feeds
February 21, 2012, 03:15 PM -
I am working for 5 days on this project. Revit just suddenly clashed, and all my work has gone.
Please help, what should I do? Is there temp files...December 22, 2013, 02:55 PM
