Door Visibility in Plan Region
    Hey All,
    I'm having trouble getting a door to show properly in a plan region. I have messed with the bottom, top, cut planes, and levels etc, and still cannot get this door to show as if it was hosted on the parent level. The two doors in the screen shot attached are the same family, so I know it will show the frames when cut in section. I have even gone into the door family and unchecked the show in section box (not section box) in visibility for the door head; nothing seems to help. I've got to be missing or forgetting something.
    I tried creating a new level at -5 - 0" hosting the door to that level and messing with the plan region that way as well and it didn't make a difference.
    Thanks in advance,
    - Joe
    Really hard to troubleshoot this for you without being able to interrogate the model...
    Why do you need the top of the view so high? Did you try just setting it at -4.9' for example? (slightly higher than your cut plane)
    It looks to me as though you've captured Something else in the view either a 2D element that someone placed over the door opening, or maybe you've captured the top frame of your door in your view range...sorry really hard to tell without being able to click on things and check it out.
      Make sure your plan region surrounds the entire door including slab.
        I knew it was something simple I was missing! My need to have things tight and neat got the best of me here. Thanks Karalon and PijPiwo for your help, that solved it.
