Bottom rail under level
    Hi everyone,
    I'm currently completing a staircase design but have come into some trouble regarding the bottom rail on my railing.
    The bottom rail goes under the level and thus ends up making a collision with the flooring, as well as not looking as intended on my drawings. Also, this solution will require hiding parts of the railing and redrawing the final design in 2D because of this problem.
    Essentially I want the bottom rail to follow the stringer for the last part of the stair - Please see the attached screenshot (hopefully without the top rail doing so; I only made the break in the railing to visualize my idea of the potential visual outcome for the bottom raililng)
    Do anyone know if this is possible without too many workarounds?
    Thanks for your help in advance,
    Martin
