Revit Extension Error message
This topic is closed.
Hi Juan, what Revit do you have?
Did you get updates? What extension do you have installed? Do they work all fine?
We need some more
see youJulien
P. DAC
I innstalled the extensions that came with the subscription advantage pack (I think that's the name) but i uninstalled the extensions. I have also an extension called REVVED I think it changes the text to all CAPS and also Merges Text. That extension works fine but the message always shows up and I think its because I uninstalled the other extensions
You should check your Addin-directory. What OS are you running?
I think the problem is that the dll- or addin-files are still there whilst the program itself is deleted. I think if you go to the Addin-directory and manually delete those files this should end the messages.Martijn de Riet
Have you looked in the Revit.ini file ? I know that Revit 2011 has improved the add-in registration facility using add-in manifest files, but from my understanding, developers can still choose to use the revit.ini
If there´s no sign in the .ini file, maybe the below blog post by Ryan Duell can help ?
Originally posted by Ryan Duell - Revit ClinicDisable Add-Ins for Revit 2011 Products
There may be an occasion where you want to test Revit 2011 with add-ins disabled.
By default in Revit 2011 products the Add-Ins components have been moved from the Revit.ini file to a separate location. While you can still utilize the Revit.ini for this release, the default location is now listed below.
If you want to test Revit with all add-ins disabled [or selectively disable add-ins] follow the steps below:
1. Close Revit 2011
2. Locate the following folder:
Windows Vista \ Windows 7 - C:\ProgramData\Autodesk\Revit\Addins\2011
Windows XP - C:\Documents and Settings\All Users\Application Data\Autodesk\REVIT\Addins\2011
3. Temporarily move the add-in files from the folder above to another location.
4. Launch Revit 2011; add-ins will be disabled.
When testing is complete you can move the add-in files back into the original folder.Klaus Munkholm
Guys,
Revit Extensions 2012 comes as part of the annual Autodesk Subscription, it's a tab in Revit (RST for me not sure if also in RAC) that...-
Channel: Structure - Interoperability
February 13, 2012, 08:23 AM -
How could I get free for the extension files?
And when i got it, how should i install or update to be able to use it.
Thanks-
February 7, 2012, 06:09 PM -
Does anyone know if it is possible to create an "error message" in Revit 2012 or a later version? for example: if someone is using your family...
Channel: MEP - Family Creation
July 1, 2013, 02:10 PM -
I accidentally clicked on and ticked "Do not show this message again" when an error message popped up in Revit 2016 and then clicked closed,...July 10, 2017, 10:38 PM
Hi all, I'm trying to export my structural model made with Revit 2013 (all in one), but I need one extension to do that, in the Autodesk subscription...
February 14, 2013, 04:20 PM -
