Hi friends, W 'd like to start a new MEP project and add HVAC requirements into the architectural Revit 3D model that we have already received from our client , which activities we have to do to start HVAC modeling...? For instance Levels and grid match and etc...Tanx
How to start new project in Revit MEP when architectural revit model has received...
Create a new empty project (With an MEP template if you have one, if not use this project to create one. See other posts on making templates..) and then link the architects model into it (Use Origin to Origin setting).
Make a section view and use Copy Monitor to copy the Architects levels.
Go to View->Floor Plans and create some views for all your levels.
In the floor plans use Copy Monitor again to copy the Grid Lines.
Also good to make a Scope Box that is just a bit bigger than the building to crop your floor plans with.
Use a view template with your floor plans (Coordination with everything on for working views).
Also useful to;
Make a workset for each linked model (So you can close them without unloading)
Set links to Room Bounding so you can make Spaces.
That should get you started..."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Hi all!
Just to make sure if I got everything correct I am asking more experienced users to give me opinion. Please find below how I see...-
Channel: MEP - General
November 2, 2015, 05:38 PM -
From a Revit MEP or Structure perspective getting a project started, without delving into subtlety, should look something like this....
- Link the
Channel: Blog Feeds
May 22, 2014, 09:45 PM -
So I have linked the Architects Model into a new project and I want to create a floor plan for each of his levels. How do I go about doing this?
September 20, 2012, 01:43 PM -
All,
I have a model with Structure, MEP and Second Arch Revit model linked.
Each model has their own grids and levels.
therefore,...October 17, 2012, 02:01 PM -
So I have a Revit model from the architect, if I open this model on it's own I can select the several floor plans (via the view tab, plan views then floor...August 16, 2012, 08:35 AM
