I am building a complex component based framing family and in some cases I need nested families to be "Null". So far I managed to implement it with an empty family, but this results in the identical instances error. I could shift them apart with more formulas, but the component is already heavier than I'd like. Is there a way to implement nested null families? Sorry i can't share the component for various reasons.
Null family type
I'd either use a <family type> parameter, if that makes sense, or use a formula to turn off the family's visibility (which would still generate the error). In some cases the error is unavoidable (such as when I have one instance that is is for when array count = 1, and another that is arrayed for when array count is greater than 1) I figure that the warning is more to remind users that the components overlap, and it's up to me to manage the graphics. I have never tried to move something out of the way to prevent the error, nor have I noticed issues in family performance when that error is present.Julie Kidder
Architect + BIM Director
There's a post on the Revit Ideas page about allowing Arrays of 0 or 1
https://forums.autodesk.com/t5/revit.../idi-p/6352220
it's marked as "Under Review", so there's chance it might happen.
Please go vote it up to give it a better chance.Dave Plumb
BWBR Architects; St Paul, MN
It depends on how you are making it *null.*
If its simply an empty family, but it IS set to be visible, that warning WILL carry through to the project, if its a Shared Family.
If its set to NOT be visible, then- as Greg said- you can leave it, it wont cause any issues.
There are several ways to make families null, including a third FT parameter that is reporting only, simply using a formula to report one FT parameter or another. But, since you cant share the family, were all just guessing as to what the real problem is. Sorry!
So, I'm trying to build an industrial sliding door family from scratch, and the basics are good and all, but I noticed some weird behavior when I insert...
September 16, 2011, 06:27 AM -
I have been adapting a fireplace family from a previous project in my office, it functions fine when editing the family, but then when I load into my...
January 21, 2016, 07:12 PM -
Hello all,
I get this when i try and load a family type catalog.
here is the txt file line.
here is the parameter...-
January 7, 2019, 10:46 PM -
I'm trying to load a light fixture family, that I created, into my Revit 2014 project and am getting an error. The family name is "Box.rfa"....-
January 26, 2015, 03:48 PM -
My Revit teacher gave me that little trick to apply a certain limit to a family.
Think about a tiny steel joist that is much...-
February 20, 2012, 01:23 AM -
