CSiRevit to Revit Structure Workflow
    We've recently contacted CSI and was able to get a month trial for CSiRevit 2016 - problem we've encountered was floor mesh from Etabs is way to may polylines it takes hours to "create" file to Revit 2016. Not to mention, the tech support that was unpleasantly and answering with generic "uninstall/install" replies that took 24 hours everytime. - anyone here that successfully implemented a workflow from Etabs and SAFE to Revit?
    Hi xin,
    we came across this issue a lot, usually you tend to mesh elements in Etabs or Sap which you wouldn't do in Revit. This is why we implemented a solution for auto joining meshed elements in Konstru. This way you can easily translate a meshes Etabs model to Revit and importing it is way faster as well. You can learn more about it here. Let me know if this works for you as a solution.
    Max
