3D view disappearing when I rotate
    Hi! I'm new here but I'm glad I found this forum and hopefully someone can answer my question quickly since I have a project due on Wednesday! When I switch to 3D view and then try to rotate, even slightly, my project zooms all the way out. Also, my properties box and project browser box won't snap to the left side. I don't know what I did!
    Hi Melisa. Welcome to the forum
    Regarding the 3D view. When you orbit in Revit it always rotate around your selected object. If you haven't selected anything it will rotate around the center of the model, and if the model is very large it will mess with you, so try selecting the element you want to orbit around.
    Regarding the properties/browser. I haven't seen that before, but have you tried doubleclicking the panel ribbon?
      If the panel has become undocked drag it to side you want it to dock too - you should see a grey outline indicating where it will snap, when you let go it will snap there.
      Julie Kidder
      Architect + BIM Director
