Hello,
I have to dimension sections with spot elevations. I quickly realized that this is quite the repetitive job, especially if some elements get deleted, case in which you must place a manual dimension again, buut mainly for the speed, it takes ages.
A thought came up: would it be possible to create some kind of a family or a custom dimension of some sort that instead of displaying the distance between points, would actually display the vertical height based on the Project level ? and no, I don't mean a continuous linear dimension starting with 0 -1-2-3
Do you guys know what I mean?:beer:
