I am using Revit 2017 and working on fairly large family (more than 10mb) which is a truss type structure. From family to project, I could load into the folder but from folder to project plan, elevation or any view it won't allow. I checked with mock-up( smaller size) to load in the same way, it was successful. I had increased the RAM to 32GB, but still the same result. Does anyone had the same experience and resolved?
Revit does not show loaded family
Originally posted by yasuooda View PostI am using Revit 2017 and working on fairly large family (more than 10mb) which is a truss type structure. From family to project, I could load into the folder but from folder to project plan, elevation or any view it won't allow. I checked with mock-up( smaller size) to load in the same way, it was successful. I had increased the RAM to 32GB, but still the same result. Does anyone had the same experience and resolved?I'm retired, if you don't like it, go around!
Originally posted by Dave Jones View Postwhat do you mean by "load into folder"? In Revit a family is loaded into a project and it is then located in the Project Browser based on what category the family is...From there you use Create an Instance to place the family. Certain categories can't be placed in certain views.
If I try to load small family it should not have problems. (mass is visible by the way) It think this is associated with the same of the family.
Originally posted by yasuooda View PostThank you David, Wrong term I used. I could load big file family under Mass category can be loaded into project. I can see the instance in the mass family in the project browser. When I crick the name of the mass (Pavilion I named) thumb nail shows up. So it is sure the the family is loaded. But When I bring the instance to lets say level 1, it keeps regenerating and never stop.
If I try to load small family it should not have problems. (mass is visible by the way) It think this is associated with the same of the family.I'm retired, if you don't like it, go around!
Originally posted by Dave Jones View Postcan't help I'm afraid as I've never had to deal with a mass family that large
After hours of attempt by Revit to locate instance in the view, it finally showed up. But somehow 4 of them in slightly different locations. I have deleted 3 and working on one now. Revit was warning like "over 10MB family will slow you down" and my family file is about 18 MB after simplified the design (it was over 60MB before). Since my RAM is now 32GB, it does not seem to be a RAM issue, it looks like Revit's internal one which I think only programmer can resolve in a future version.
Anyway it still has some minor quirky things that has to be resolved, fundamental issues were resolved.
Thank you for your advice!
Im doing a project for university and I'm trying to load a playground, which I downloaded from site. The file is type RFA. I tried to open it and load...
November 26, 2014, 07:09 AM -
Hi everyone,
this might sound as a silly question but it's really driving me crazy.
On a rvt file I'm working on (but that I didn't create)...April 18, 2021, 07:01 PM -
Hey all
Ive started to use revit very recently and am having problems with families. I'll give you an example
When inserting...March 12, 2011, 09:55 PM -
A while back, RevitCat got me thinking about the rules associate with family swapping in Revit. Here are a couple:
- You can change the Categ
Channel: Blog Feeds
February 11, 2013, 11:15 AM -
when i am trying load family (any object from library or find online) by option insert->load family and choose file nothing happend, the...December 14, 2015, 03:49 PM
