Leader Attachment for Tags
    Searched for a way to control this only to find a bunch of old threads saying there isn't a way to change the default of the attachment points from the middle of the extents of the elements in the tag. Saw a trick mentioned in this forum of using invisible lines but that would be the same on either side of the tag. I'm looking for upper left and lower right attachment points.
    Has this option become available?
    As far as I know, no. Some use a left justified and a right justified type to get around this.
      This is correct. And if you want the leader to move relative to the notation, I think you'll actually need to move the notation in the family around. If you group the symbol/label/etc. with some invisible lines you can move the group around with dimensions.
      Greg McDowell Jr
      about.me/GMcDowellJr
