Hi All. New Member here...
How do I set up the view range to show everything that i need to show on 1 plan.
I draw on First Floor which is set to 2720mm
I want to view the Walls below the first floor and be able to work with them from first floor level.
I want all the brick walls to be hatched unless there is an opening (Generic Model) in the wall
I want to see the hollow core slabs (Structural Framing) - as this is my main purpose for using revit.
I also need to show walls on top of the hollow core slabs in a dashed line.
This is what it looks like with my current plan view and view range.
In the clouded area there is an opening as per 3D
This opening shows hatched on first floor plan, but i want it to show like this View Range also.
But now my Hollow Core Slabs (Structural Framing) does not show up properly and I can't select them, to change details.
I had a workaround with this, by making the opening height 2720 if I only needed to submit a 2D Plan, but want it in 3D to be correct as well
Any suggestions
Any suggestions
