Spiral Stairs
    Spiral Stairs
    Hi there,
    I am trying to draw a spiral staircase by Component.
    When the stairs are drawn in "Properties" window I can not change an actual Riser Height.
    How can I draw those stairs,when I could type a Riser Height as I want?
    Cheers,
    Regards
    Not sure if you're talking instance or type properties but you should be able to change min. run and max. riser in type properties.
      Elton,
      In Properties box I can not change a Riser Height.
      Any advice?
      Thanks
        Before you start modeling the components, click "Edit Type" in properties and specify your wanted stiar parameters. Otherwise it's probably gonna get messy
          Or...make a single run of whatever length/height, select it then hit edit type. Adjust parameters, click OK. Ignore warnings and delete original stair, then -without cancelling- make new stair as desired.
          Stairs in Revit are really tricky and there's different system types that won't interchange. Post some screenshots if you're still having trouble.
