For several days I've been trying to replace an old project linked file with a new version. The new file was "initiated" up to BIM360 as normal and I can see it along with all of our other linked models and our main model using Manage Cloud Models. When I do a Manage Links, select the old model, and hit Reload From I get a dialog that seems to be the BIM360 root directory but it is empty. Today I tried this process with other models in the Manage Links dialog and get the same results. All of our models show in the Open/BIM360 Team dialog and the all open normally. I reinstalled C4R v9 for R2016 today without any change in results. I'm about to do a milestone printing of 700+ sheets and need to get the latest linked model loaded. Any ideas?
Unable to Reload From to replace an old linked model with a new version
I only have access to one project in 2016 C4R, and oddly it says that it can't find the file to even open it. 2017 C4R open/offer reload from as expected.
Are you able to get to manage cloud models? I had an issue with how newer versions of Revit 17 interacted with older C4R and couldn't manage models for awhile.
As a last resort, could you publish & download the latest & greatest & link it in locally until you find a permenent solution?Julie Kidder
Architect + BIM Director
Originally posted by jmk View PostI only have access to one project in 2016 C4R, and oddly it says that it can't find the file to even open it. 2017 C4R open/offer reload from as expected.
As a last resort, could you publish & download the latest & greatest & link it in locally until you find a permenent solution?I'm retired, if you don't like it, go around!
Try closing Revit, cold-re-boot your PC, the Clear you Cache. Then re-open Revit, try Manage Links again.
We are having some "missing" or "vanishing" Links problems on C4R 2017 in the past few days on various projects. The technique above has resolved it temporarily, but it then re-surfaces again at random times.
We also found that logging out and then signing in to your Autodesk account in the Revit dialogue box "refreshed" it.Cliff B. Collins
Registered Architect
Autodesk Expert Elite
Originally posted by cliff collins View PostTry closing Revit, cold-re-boot your PC, the Clear you Cache. Then re-open Revit, try Manage Links again.
We also found that logging out and then signing in to your Autodesk account in the Revit dialogue box "refreshed" it.I'm retired, if you don't like it, go around!
Originally posted by Dave Jones View Postas a follow up I have started an Autodesk support ticket about this issue. There was a post in the Adesk Revit Collaboration forum from someone with exactly the same issue so at least I know that I'm not crazy
-KyleDirector
Building Design Strategy
Hello - I have my model and a bunch of linked files on C4R. I receive new Revit models weekly from the GC which I have linked into my model. I tried...
Channel: Worksharing and Cloud Coordination
July 6, 2017, 01:33 PM -
what are the best practices for uploading models to C4R?
if you have an existing project with arch and structural linked (a mep job) do...-
May 23, 2017, 08:33 PM -
We've run into an issue today that we consider to be major and unintended. Published models that are downloaded and opened will sync any changes back...
July 20, 2017, 06:49 PM -
I'm testing C4R now. It hasn't happened yet, but I know it'll come up very soon.
Me being an MEP , the Arch/Strc models are usually...-
November 10, 2015, 08:33 PM -
Would anybody be able to help guide me through the process of updating linked files using C4R? I've read through the Help and can't seem to find the correct...
January 28, 2016, 02:19 PM -
