Hi Guys, I'm experiencing a quite bizarre behavior with my material editor, I'm working in Revit 2017.2 in a new project I just started last Monday using my own template, so I'm working to have some renders for this projects and I noticed that my material editor has been populated with a lot of random materials called "Render material 255-255-255" and so on, no matter how many times I delete those materials once I open my material editor I found it again and again, have you already experienced this type of behavior?, thanks’ in advance
Materials Odd Behavior
Hi elton williams, Thank's for your answer, yes I found it yesterday when I unload and re-load an imported dwg I was using in my Revit file :blah:, since I unloaded the cad file and get rid of those materials the Material Editor was clean but I noticed that the materials reappeared in the Revit file just when I reloaded the cad, regards and thanks againAndres Franco - Architect - BIM Coordinator
E.A Poe
They'll keep coming back each time you bring in cad and so will the import categories. You can either clean up the file in cad before importing or just delete them in revit which will make all the subcategories change to default (usually black ) lines, or whatever you set the import category to.There are no stupid questions, only stupid people
hi i m sorry on my bad english.
i have a problem to import cad to revit.
when i tried to render the matirial is grey.
i success to...November 27, 2011, 07:02 PM -
Is there a best practice way to achieve the result desired in the title- as in importing a sketchup file into revit 2011, applying materials and getting...January 15, 2012, 11:06 PM
Can't remember if I have mentioned this FREE little addin for cleaning out your Materials list before.
If you have ever tried to clean out your...-
Channel: Third party Add-Ins, API and R&D
February 19, 2011, 02:22 AM -
Not quite sure which forum to enter this in... But here it goes:
How do I email / post / wetransfer an .adsklib file WITHOUT it getting corrupted?...February 21, 2013, 10:13 AM -
Hi guys,
Is there a clever way to change the material of a component in a family based on another parameter like a tick box?
Channel: MEP - General
February 10, 2016, 10:17 AM -
