Cant able to Edit Section name Key
    I'm using a structural Column Template.
    here I cant able to Edit the text section name key.
    Thanks for solving the Issue.
    Dhilip Seshan
    +91 8124181665
    www.dhilipseshan.n.nu
    Not sure why you would want to change this as it is a built in parameter.
    However, it can be changed in the text file that relates to the section shape you have used (in this case UB-Universal Beams-Column.txt).
    This can be found in the same directory as the rfa file.
    I really don't think that this file should be edited - so do at your own risk.
      Thanks you Melnyk. Just we are Creating our Company Standard Families. For that Families which are Created by our Company Standards needs to Fill the Data.
      Dhilip Seshan
      +91 8124181665
