Vertical cable tray connection
    Its anyway to do this type of connection between cable trays in Revit?
    Thanks in advance
    Probably..
    Try editing a T and move the side connector to the bottom.
    Although for it to connect properly, the centreline of the connector from below might need to be in line with the centreline of the tray above.
    • Cable Tray Reducer
      how to make left side and right side cable tray reducer in revit-2017
      :bb:
      please help me. I'm new revit user
      June 10, 2016, 11:02 AM
    • Cable Tray Noise Barriers
      I'm new to Revit and can't find any information on handling noise barriers in cable trays. Seems like an important item to have in a cable tray design....
      June 13, 2017, 12:46 PM
    • Drawing Cable Tray on an arc
      Got do draw a run of cable tray 1 metre offset from an arced wall. I've drawn a detail line as a marker. Please see image attached.
      What's...
      May 18, 2016, 02:15 PM
    • Cable Tray Clearance Space
      What's the best way to place clearance for cable tray? I wish cable tray had an option similar to piping insulation except it added clearance space....
      May 21, 2015, 02:22 PM
    • Cable Tray Offset-MEP
      How to chnage cable tray offset height middle to bottom
      ex: cable tray offset i fixed in 1200 but in section view it is 1150,,,...
      June 3, 2016, 06:07 PM
