Reversed window.
    Reversed window.
    Hi.
    I created a window family with Rough Width and Rough Height as instance parameters and Height = Rough Height (*)
    and tag that shows RW, RH, Sill Height and Head Height* ("spód", "góra" on the attached pictures).
    In the model it behaves like that:
    Tag shows correct value of each parameter but...
    Phisically Sill Height is in proper position but Head Height is reversed - it "grows" down like the window was roteted 180 degree.
    Any idea what happened or how to repair this?
    I removed Head reference plane, put new one, constrained what I nedded and it works fine again.
    Earlier I changed the dimension label from Height to Rough Height...I think after that it "broke down".
    But why?
      Head Height is Sill Height+Height. Which is totally silly, because it should be Sill Height+Rough Height.
        Exactly. That's why I had to make Height = Rough Height in this situation.
