I've been working on my first R2017 project for the last few days and the dialog that pops up when I finish creating text is driving me nuts . Create text, done, Escape, left click with the mouse, another create text box pops up, if you then hit Escape again the "Do you want to keep changes in your text note? dialog pops up. One either needs to hit Escape twice or use the Modify button Way Up There At the Left Top. Can't get out of it with another Escape, one must manually click on Yes, No, or Cancel. I fully understand why some might find this useful but I find it annoying. When I'm done, I'm done, leave me alone! Is there any way in the .ini to turn this off??
Cancel Editing Text Grrrr!
Originally posted by Dave Jones View PostI've been working on my first R2017 project for the last few days and the dialog that pops up when I finish creating text is driving me nuts . Create text, done, Escape, left click with the mouse, another create text box pops up, if you then hit Escape again the "Do you want to keep changes in your text note? dialog pops up. One either needs to hit Escape twice or use the Modify button Way Up There At the Left Top. Can't get out of it with another Escape, one must manually click on Yes, No, or Cancel. I fully understand why some might find this useful but I find it annoying. When I'm done, I'm done, leave me alone! Is there any way in the .ini to turn this off??
Yes, this is very annoying ESC twice has always gotten out of any command and back to modify. Having to click yes is just awful.Scott D. Brown, AIA | Senior Project Manager | Beck Group
Hi Dave et al--
Help me understand your exact workflow, and what behavior wouild you like to see instead.
Here is text note creation in Revit 2017+ (new text):
Revit 2017+
1. Choose Text tool
2. Click in the view to start a new text note
3. Type some text
4. Click outside of the text note to complete it
5. Double-click Esc to exit the text tool
It sounds to me like the issue is that at step 5 you click Esc only once (the text tool remains active), then left-click in the view. This starts a new text note... but you didn't want that--and now clicking Esc twice doesn't exit the tool because of the "Do you want to keep the changes in your note" dialog box.
Perhaps the solution would be to only fire that dialog if you click Esc after actually typing some text in the text box? If it's blank, as in your example, Revit should know that you don't want to save that text note.
Does that sound reasonable, or do you have some other suggestions?
Thanks,
Trey
[email protected]
I've always just clicked outside the text field to finish text editing. I learned to never use ESC in past releases because that just killed the text editing work WITHOUT any warning. With 2017 it now warns you when you use ESC to help avoid losing the work. If you press ESC once and then Y it will choose the Yes response in the warning dialog. Using ESC twice chooses Cancel in the warning dialog, leaves you in the editing mode.
Also, when they reworked the text editor for 2017 they assigned the combination of CTRL + Q as the default keyboard Shortcut for the command Close Text Editor, the Close button on the editor ribbon. You can assign your own but the editor HAS to have a CTRL key combination to work. Try using something else and a warning will pop up to let you know you can't.
Edit: I just noticed that in 2018 there is no default keyboard shortcut for Close Text Editor. Also in 2017 and 2018 I find that when/if I use the Keyboard Shortcut a warning sound occurs each time. If I just use ESC and then Y...no bell. It seems to regard the use of the keyboard shortcut as some sort of error deserving of a warning, that's weird.Attached FilesLast edited by Steve_Stafford; July 2, 2017, 01:58 AM.
I read a post at AUGI tonight that mentioned using the Modify button on the ribbon to finish typing or editing text. The intended technique to finish...
Channel: Blog Feeds
November 2, 2013, 05:15 AM -
2017 added this menu after pressing esc from a text element. This drives me up a wall.
...February 9, 2017, 03:16 PM -
I'm getting hammered by this box thing today - constantly having to re-do text because of the text entry behavior. Once the drop-down appears, keyboard...August 16, 2017, 01:23 AM
I use multi line text either bulleted or numbered for my drawing sheet notes but can't seem to get a space between each section. The text ends up numbered...
Channel: MEP - General
July 2, 2015, 05:54 PM -
Anyone else's text editor not work? Very frustrating.
When I edit any text (upgraded or new), I can't pick a spot and start editing....April 21, 2016, 03:42 PM
